Salta al contenuto principale
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 Domande Visualizza tutte
Tail lights staying on like im pushing on the breaks all the time
(1998 Chevy k1500 z71 5.7L) My trucks brake lights stay on. Replaced the brake light switch under the steering column and the brake light relay under the hood. The relay itself is hot under the hood but I imagine that's due to the lights constantly staying on. If I remove the relay the lights will shut off and when I put it back on they stay off until I start the truck and hit the brakes then they stay lit up. What do I do? Needing some help about now.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@cmcowan1990 with the relay removed, have you checked to see if you have constant power to the relay. unplug your brake light switch and see if that power to the relay cuts off. If so you are either having an issue with the new brake switch (double check your work) or you are having a short in the wiring.
Punteggio 1
Aggiungi la tua risposta
Chad Cowan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 44
Tutti i Tempi: 9,814
