Salta al contenuto principale
A collection of guides and support to help with washer repair.
3473 Domande Visualizza tutte
Why is my washer making clunking noise during agitation?
I have a maytag MAV408dawk legacy series washer. Bought in 2006. It is making a clunking noise when agitating. Sounds like it's coming from the middle of the agitator. Any ideas ?
Thanks, Mike
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Cause 1
Tub Bearing
The tub bearing is mounted in the middle of the outer tub. The tub bearing helps to keep the inner tub spinning smoothly. Replacing the tub bearing is a very involved repair and will require disassembling most of the washer. If the tub bearing is defective, we recommend replacing both the outer tub and bearing as an assembly if the manufacturer offers the components together.
Punteggio 2
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 520
