It not powering up
The cord lights up when I plug it in but when I plug it into the laptop the light goes off on the cord and no lights come on on the laptop
Questa è una buona domanda?
# Turn off the computer and remove the power cord.
# Remove two screws holding a panel on back in place.
# Next to the memory card you will see a switch which you need to turn to the OFF position
# Reboot your computer
Once the operating system boots correctly...
# Remove two screws holding a panel on the back cover.
# Next to the memory card you will see a switch which you need to turn to the ON position
The error has been cleared and your system should work properly.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 265
