Salta al contenuto principale
6th generation Android smartphone designed by Google and manufactured by Huawei. Released October 2015.
63 Domande Visualizza tutte
Replaced battery and caused damage to cable and/or screen
I replaced my Nexus 6P battery for the second time (the first time it worked just fine, but the new battery was crappy and it only lasted a few months).
After replacing the battery (the second time), the phone now does not appear to start up and I think the cable below the battery may have been damaged when I pulled the battery out. Pressing the power button triggers the "vibrate" on the phone but the screen does not light up and it does not appear to boot up.
Has anyone else had a similar issue? Is there any way to replace this cable without replacing the entire screen? Or is there something else that might have caused this issue during the battery replacement (the rest seemed pretty straightforward).
Questa è una buona domanda?
Punteggio 0
1 Commento
teardown guide and parts for the phone can be found here
Nexus 6P
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Just a thought ... if you can see the trace lines on the ribbon cable and see where they are damaged you may be able to fix them withconductive glue . Each trace will need to be kept separate from the rest . so great care will be the order of the day when applying the glue and you will need to cover the ribbon withliquid electrical tape when done . Hope this helps
Punteggio 1
Risposta Più Utile
I would say take it back apart and check for cable damage. These things tear quite easily.
Update (12/30/2017)
If the cable is damaged then yes you will need to get another replacement screen.
Punteggio 3
2 Commenti:
So it's not possible to replace the cable without replacing the entire screen?
da
not without some special equipment and mad skills
da
Aggiungi la tua risposta
Tara Zieminek sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 964
