How To Swap Nand Chip in iPhone 5s?
Hello guys my iphone 5s stucked in boot loop so i wana know can we swap One Nand Chip from one phone to another phone or can we repair nand chip?
Questa è una buona domanda?
Are you sure boot loop is caused by bad nand?
What iTunes restore error do you get if you tried restore? 4013?
NAND would need to be removed and reprogrammed using a naviplus tool, not sure exactly what it's called.
yeah i am sure coz i am getting 4013 error . I dont Have this Navi plus tool is there any case i can repair or swap any chip without this tool?
There is no point in swapping the chip without reprogramming it with the tool.
The NAND stores important information that is linked to its original Logic Board...Serial Number, WiFi and Bluetooth Mac...The Naviplus Pro 3000 will allow you to read the IC and write to IC with a Format and fix option. You can buy this tool for about $200 to $250 (US) or search for a repair shop that has one who can program it for you. You most likely do not need a New IC as the ones I have dealt with so far can just be reballed after programming...unless you are wanting to upgrade the storage capacity at the same time of repair, then you can buy a larger capacity NAND to reinstall
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 3,331
