Salta al contenuto principale
Quinta generazione dell'iPhone. La riparazione di questo dispositivo è semplice e richiede cacciaviti, strumenti di apertura e pazienza. Nero o bianco, GSM/CDMA / 16, 32, o 64 GB.
2193 Domande Visualizza tutte
When I turn off my iPhone, it turns on at the moment, like a restart.
I don't know why my iphone 4s restarts when i only turn off it... The battery was changed, but in a chinese electronic shop. But i think that is caused by a problem on the motherboard, but i had been reading in some foros that it could be a problem on the dock or battery. Someone could help me to solve this problem? i would like to have a repared iphone....
Thanks a lot!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Open up the phone and unplug the power cable from the motherboard; see step 17 of this guide:
Sostituzione pulsante di accensione iPhone 4S
Turn off the phone. Does it reboot again? If not, replace the power button cable. If so, disconnect the dock connector cable (step 8 of the same guide as above) and turn the phone off again. If it doesn't reboot again then you need to replace your dock connector. If it does (highly unlikely) then something else is amiss.
Punteggio 0
Aggiungi la tua risposta
Julio sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 26
