When I hold the power button only the fans turn on
I unscrewed the the bottom of the laptop to dust it off and when I screwed it back the laptop won't turn on except for the fans
Questa è una buona domanda?
What did you use to dust it off? Canned air can cause liquid damage, compressed air can have water in the line or be too strong. A vacuum can give of a static discharge. I use an electric blower, and a tooth brush.
Also try unplugging the laptop and removing the battery and holding the power button down to discharge the electricity.
I used a feather duster to dust off the whole thing and a toothbrush for the fans
did you ever find a solution to this? I just ran into the exact issue without even taking it apart to clean out
i fixed it by unplugging the battery and then re-plugging it again. you're gonna have to unscrew the bottom of the laptop to do that.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,161
1 Commento
Did you ever find a solution to this? I just ran into the same issue
da Matthew Waldmann
