Why is one of my propelers is not working
Every time I turn my drone on one of the propelers won't work
Questa è una buona domanda?
Punteggio
0
Do you still have it?
There is a screw that goes through the propeller and the shaft, on the bottom gear you have the same set up. the screws will shear in the shaft preventing a simple replacement. You may have to drill out to free the broken screw inside the shaft, through the top worked for me
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 365
It could be the screw that holds the propeller to the shaft; sometimes the break
da lild.james
