Salta al contenuto principale
The Epson Artisan 1430 is a color inkjet photo printer.
32 Domande Visualizza tutte
removing cover artison 1430
I have a new Artison 1430, and want to remove the side panel for waste-ink adaption. On you-tube it shows tabs to be lifted, but my model has a smooth surface so obviously is a later model, and has no tabs showing. I'm afraid a repair manual may not be up-to-date. Anyone can help?
Questa è una buona domanda?
Punteggio 2
1 Commento
www.baharchap.com
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
OK, it's not very obvious, but the front panel on the right-hand side is just a cover plate` which pulls straight forward for removal. this exposes the 3 front tabs of the side panel, which are easilyprised free, and that allows the side panel to be worked upwards, disconnecting the remaining tabs, and removed.
Punteggio 3
2 Commenti:
Oh, I forgot: undo the centre and right-hand screws on the lower edge of the rear panel first, then prise the right-hand side of that rear panel to release the rear tabs of the side panel. This should be done first.
da
thanks charles. i wonder what other repair knowledge you have for the 1430, as i get really good photo prints with it. greg wheeler
da
can someone help me i have the same artisan 1430 printer, i tried to clean the printhead by dipping it in the windex maybe too submerged, i installed the printhead started to do cleaning at some point with the printhead almost all the way to the left went off and does not turn on anymore
Punteggio 0
1 Commento:
Did you ever get this fixed? Mine won't turn on either.
da
Aggiungi la tua risposta
George August sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 849
