Salta al contenuto principale
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
66 Domande Visualizza tutte
Domanda Chiusa
Why does it keep saying "not responding"?
Every time I try to open the My Pictures folder, or try to save a picture off the internet, or various other actions. it will stop responding. I've run a virus scan like 12 times, but it's only found 2 problems max, yet the "not responding" problem persists.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Aaron, this sounds like a software issue. Since you have had at least 2 viruses on your computer, it is possible that you have a registry error. I would try to restore your OS I am going out on a limb here and say you are running Windows. there is a way to restore it without replacing your data and programs. There is a solution here and another good one here good luck to you.
Punteggio 0
Hi,
Download and run CCcleaner for registry repairs and see if your problem goes away.
Try reinstalling VGA drivers.
if that did not work then you have to reinstall the windows using Window install CD.
Insert the Install CD and click option repair windows to save your data.
The best way is to copy all of your data into an external H.D.D and format all drives and install a clean windows for clean pc.
Good Luck.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,454
