Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
Smoking battery while replacing. How to deal with it?
Hey guys,
I was replacing the battery of my iPhone SE. The glue bands got cut, so in the process I accidentally punctured the battery several times.
On my ignorance (I underestimated the procedures, I'm terribly sorry about this, never again!!!) I bended a little bit the battery to got access to the glue bands underneath it with the tweezers. So, it flashed out of nowhere and smoked a little bit. I assume the lithium is extremely reactive to humidity, that's why the
At this point, I left the iPhone on the work surface as is, but I truly don't know how to deal with this.
Thanks in advance for your answer, guys!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
well you are lucky the phone could have went on fire, realistically I wouldn't have that battery in my house.
once the battery stops smoking you can try again but to be warned you have to be very carful with lithium polymer batteries.
if you have a metal sink id leave it in there or outside. In my tech department we use a safe for punctured batteries so its smothered.
if it feels hot while your working on it put it down. for future reference there are pull tabs on the glue and if you break those usally a low heat hairdryer works to soften the glue before removing the battery.
Punteggio 1
Aggiungi la tua risposta
smarinpavez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,498
