Salta al contenuto principale
These white headphones are equipped with a remote and mic, and come with Apple's music players and iPhone. They are also sold separately. Released on September 9, 2008.
6 Domande Visualizza tutte
How to fix earbud board with lost continuity?
So I’ve run into a problem. I was dismantling some in-ear headphones for a project and the first one worked out fine but the second has an issue.
There are 4 terminals on the board. All but the bottom right one (in the images) have continuity with each other in the working driver. The driver that is having trouble has lost continuity with the bottom right terminal. I didn’t treat it any differently than the first one but something must have happened. The only thing that makes any sense to me is perhaps I got it too hot when desoldering the terminal.
If this is the case, is there any way to fix it? Any suggestions as to how to troubleshoot any further? If anyone has an idea about how I might salvage this, I would greatly appreciate it.
Interior of not working driver:
https://ibb.co/c0QmKm
Exterior of not working driver:
https://ibb.co/mEQWkR
Wiring of the working driver:
https://ibb.co/mvDj5R
Please note these aren’t actually Apple headphones but from what I’ve seen of the internals of the Apple ones, these are similar.
Thanks in advance :)
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your question seems to contradict itself regarding the bottom right pad.
However, 2 of the pads, as you'll see, are for soldering the earphone lead to (let's call them A and D), and each of these is connected by printed circuit tracks to one of the remaining two (call them B and C, A connected to B and D connected to C). The two ends of the voice coil are soldered to B and C. You may have difficulty seeing this as the voicecoil is made up of very fine wire.
The only way you could have just one pad with no connectivity to any of the others is if one of the printed circuit tracks were broken. That doesn't seem likely, though it's just possible you broke the track in unsoldering the earphone wire. In that case you should be able to bridge the break with solder.
More likely is that the voicecoil wire is broken. This would show up by continuity between A and B and between C and D, but none between A or B and C or D. This would probably be very difficult to fix. If you have around 30 ohms between B and C your voicecoil is good.
Punteggio 1
Aggiungi la tua risposta
brandonbarks sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 134
