Why won't my laptop show my available networks so I can connect toWiFi
Trying to connect to the WiFi in my home and my computer won't show me the available networks to connect to.
Questa è una buona domanda?
Hi Tarah Smith,
Good Day
Check under Device Manager, if your Wireless Hardware is detected in the system. Is flight mode activated?
If it is detected, try updating drivers and see if it helps,
If the hardware is not detected, proceed to next step to BIOS to check if it has been disabled.
Consider updating your laptop BIOS
Certain laptops has a wifi switch, can be either located on the side of laptop or using keyboard options.
Fn + Keys
Else if the drivers has been updated and flight mode has not been disabled, and you are not seeing any SSID, (applies to hardware wifi switch), the hardware switch might be faulty.
There is a workaround to tape the pins to use.
Please check and let us know :)
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,162
1 Commento
Tarah Smith what model is your computer?
da oldturkey03
