Salta al contenuto principale
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
20 Domande Visualizza tutte
Why is my 2006 Dodge Caravan stalling out on me
I have a 2006 Dodge Caravan which when driving my vehicle every time I step on the brake my dash goes haywire and the lights on the dash comes on the radio goes off and then the car will stall out. 1st I changes the Plugs and Wires still continued to stall Changed the battery still continues to stall out. And now I can be driving accelerating and my car will just stall right out.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Definitely look at the ground cable , make sure its not corroded where it meets the frame ,opposite end to where the ground meets the battery. Check the ground on the fuse panel next to the battery and also reseat the ECM and the PCM they're located next to the battery . Ones below and in front of the battery and the other is on the end of the engine compartment fuse panel. Check that there's no corrosion in these connectors and use dielectric gel when reconnecting to keep the connection clean and dry. Make sure they are locked in when done. Hope this helps
Punteggio 1
Risposta Più Utile
Check for loose battery wires and charging system problems. The charging system is mainly inside the computer under the hood. Loose battery posts and power and ground cables will do this. Make sure the battery isn't weak because it can leave you stranded on a cold day.
Check the engine computer for fault codes and run a few tests before you have a thousand dollars tied up in a failed repair attempt.
Punteggio 2
Aggiungi la tua risposta
Patricia Scisson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 734
