Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2690 Domande Visualizza tutte
GPS is inaccurate and won't update location
My iPhone 6s GPS will identify my initial location in map apps, but will not follow me or update and displays inaccurate location while using navigation apps. Have tried everything to reset the device, but nothing works. Help!
Questa è una buona domanda?
Punteggio 0
3 Commenti
Are you in a car? Did you get your phone wet at some point? Are you in a rural area or in the city?
da
Using GPS primarily in the car in city and rural areas. Phone has never been wet. Have never had a problem with GPS signal before switching to the 6s. Tried turning off LTE, but still no improvement.
da
So this is a used phone then as the 6s is a few years old now. Or, you've never had it working when you bought it new?
Have you had it serviced at some point? And what for.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Scott Riggs download a simple GPS diagnostics App from places like this and test your GPS. Right now it sounds like you are having issues with your GPS IC. To possibly repair this you would require the services of a micro-solderer like @refectio or @teetopp
Punteggio 3
Aggiungi la tua risposta
Scott Riggs sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,109
