Salta al contenuto principale
Released in 2011, the Asus K53SV is a 15.6-inch laptop with a 2nd-generation Intel processor and a dedicated Nvidia graphics card.
5 Domande Visualizza tutte
Can I replace my existing K53SV motherboard with K53SM motherboard?
Hello,
I bought Asus X53SC-SX224D model on 2011 which has following specs:
- Motherboard: X53SC - K53SV REV 3.0 (PCB MADE IN CHINA)
- RAM: 2x2GB DDR3 1333
- Graphics: GT520M 1GB VRAM
- Battery: 4400mAh 4-Cell
- Processor: 2.3GHz i5 2nd Gen Processor
- DVD Writer
Now, this motherboard was damaged and I'm planning to fix it or replace it.
Can I get a new K53SM motherboard instead of K53SV? Will K53SM motherboard supports all my existing external hardware components?
Are the motherboards part number specific?
Can we use 1600mHz DDR3 RAM?
Existing K53SV: https://www.empowerlaptop.com/p/asus-x53...
New K53SM: https://www.empowerlaptop.com/p/asus-k53...
Thank you
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Hi!
You can replace your motherboard with the one you want to replace it with, they should be compatible.
As for your second question, about the RAM, you can use DDR3(/L) 1600mHz DIMMs, but they will switch automatically to 1333mHz regardless because 2nd gen Intel Core i-series chips don't support faster speeds.
Punteggio 1
2 Commenti:
Thanks Alex.
da
is the ks53m better than the ks53v?
da
Aggiungi la tua risposta
Prasanth G sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,177
