Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
iPhone keep crashing without using any app
Hello there,
I got 3 x iPhone 6 with same issue of crashing iOS this morning.
It just goes to black screen with loading sign and comes back to ask Passcode. It is not App just happens without even opening any App. It is not battery or any other hardware as I did check. As per clients it happened over night in Auckland NewZealand.
It is quite strange issue because it didn't happen straight after update.
Any one has any idea? What it could be and possible solution?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hello Ben,
The manual time thing didn't fix the issue but I found a solution, actually, it is due to notifications, So I just turned off notifications.
Settings > Notifications > Show Previews > Never
Source: https://www.theverge.com/2017/12/2/16727...
Phones are working normally. It worked for me...
Thanks
Regards
Danesh
Punteggio 0
Risposta Più Utile
The recent iOS update has a bug where if the system date and time is not set correctly the phone would keep rebooting every 5 minutes. Chances are apple will release a hotfix update for this in a few days.
The solution to this for the time being is to manually set the date and time and leave it manually set.
Punteggio 1
Aggiungi la tua risposta
Danesh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 944
