Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1185 Domande Visualizza tutte
Liquid Damage reparable? Pictures attached
hello guys,
my mbp r 2015 wouldnt start up. i detected a damaged backlight connector and pulled the logicboard out of the bottom case.
there seems to be a burnt area - is this reparable?
pictures : https://imgur.com/a/3eCs2
thanks in advance
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Pretty sure that can be fixed. I would just need to harvest the connector then solder it. Probably would have to make a jumper or 2. Would you feel comfortable with the repair yourself? You would need some microsoldering equipment and a microscope.
Punteggio 1
do i have to replace the damaged connector? i wouldnt mind to use the mbpr keyboard without the backlight?
i will use alcohol to remove the corrosion - is there more that i can do?
Punteggio 0
Aggiungi la tua risposta
M Ro sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 111
