Salta al contenuto principale
Released October 2016, identified by model number RS03QR
How do I connect my device to the internet?
I want to connect to the internet, but I'm not sure how to do so wirelessly.
Questa è una buona domanda?
Punteggio 0
1 Commento
still unable to connect,used alexa app
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
You connect your Amazon Echo Dot through the Alexa app! Go to settings, select your device, and select set up wifi! I am attaching a link which will give more help on connecting your device to the web.
https://www.amazon.com/gp/help/customer/...
Punteggio 0
Risposta Più Utile
Connect echo dot device to Wi-Fi network:
Go to Settings option from the left navigational panel.
Select your device and after select update Wi-Fi.
Try to press and hold action button when the light ring changes to an orange and select Wi-Fi network, enter the password.
Also, Make sure enter password is right to connect to the network.
Punteggio 1
If you want to connect echo dot to a Wi-Fi network, follow the instructions in the Alexa app. Most important thing that is echo dot connects to dual-band Wi-Fi (2.4 GHz/ 5 GHz) networks that use the 802.11a / b / g / n standard. Echo Dot does not connect to ad-hoc (or peer-to-peer) networks.
To learn more, go to '''Connect Echo Dot to Wi-Fi'''
Punteggio 0
Aggiungi la tua risposta
Cassidy O'Connor sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 22
Tutti i Tempi: 6,992
