Salta al contenuto principale
A tablet released in September of 2015 by Amazon featuring a 7 inch multi-touch screen display. Model Number: SV98LN
50 Domande Visualizza tutte
My Kindle wont turn on
So, basically what is happening is, my kindle refuses to turn on. I have tried doing the hard reset stuff, charging it, etc. When I power it up it says Amazon and the proceeds to sit on the "Fire" screen. If i happen to get lucky enough that it turns on, within 40 seconds the screen freezes and i cant do anything except hard reset it again. This has been going on for about 24 hours now and ive tried just about everything i can think of. there are absolutely no repair shops around and this kindle is te only way that i am able to contact anyone, help would be uch appriciated.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
  • need to install ADB drivers
  • Boot into recovery: Hold Volume Down button & Power button at the same time
Carefully read this thread/post:
https://forum.xda-developers.com/amazon-...
Post here if you are successful.
May be your battery is OLD? Try changing it. Remove your microSD card. Try a few things. or you can actually install a clean non-amazon spy-free open source software by complete unlocking. Then you have only a minimal apps - no crapware. See below:
Punteggio 0
Aggiungi la tua risposta
brianna sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 278
