Salta al contenuto principale
A1706/ EMC 3071 — Lanciato nel novembre 2016, questo MacBook Pro introduce la Touch Bar OLED. Ha CPU Intel Core i5 dual-core "Skylake"e 4 porte Thunderbolt.
239 Domande Visualizza tutte
Can bevel above hinge be replaced easily
i have Macbook pro with touch bar Model A1706
The bevel above the hinge (where it says Macbook Pro) has hairline cracks Think might be a issue using a laptop protective cover
Can it be repaired ??
Update (11/30/2017)
Thanks for reply
Ho much to repair ?Do you think a common problem?
Think damage caused by Macbook hardcase shell
see picture attached
looks as if when closing lid causes a pinch point because case clips on back by hinges
Do you think Apple would cover under warranty ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I believe what you're talking about is the clutch cover. It can be removed as illustrated in Step 3 of the Retina Display Teardown. You'll probably have to remove the display in order to be able to remove it. For that, you'll have to do some disassembly. You can follow the Touch Bar Teardown, you don't have to remove everything, like the touchpad and battery, it shouldn't be too difficult to figure out what needs to be removed and what doesn't.
At the end of that teardown is a link to another teardown where it shows how to remove the display from the chassis. Be aware that unlike some of the older MacBook screens, this isn't one isn't entirely self-contained. Some of the display electronics are now housed in the bottom assembly.
In my opinion, it's not that difficult a job, but an awful lot of trouble to go through for what is just a hairline crack.
Immagine MacBook Pro 15" Retina Display Mid 2012
Guida
MacBook Pro Retina Display Teardown
Difficoltà:
Moderato
Immagine MacBook Pro 13" Touch Bar Late 2016
Guida
Smontaggio MacBook Pro 13" Touch Bar fine 2016
Difficoltà:
Moderato
Punteggio 1
Aggiungi la tua risposta
Dav sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 550
