Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
dropped in water - now won't connect to network - says "Searching"
I dropped my iphone 5s in the toilet and afterwards put it in rice. Now it turns on and is fully functional except it won't connect to the verizon network. It says searching in upper left corner. It has an meid number and this is the only problem. How much to fix or how much can i sell this for?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@meghan009 should have skipped the rice. It will not prevent corrosion nor will it fix the phone, it is a misleading myth. The very first thing you want to do is to not try to restart the phone. This may further damage your phone. Right now your phone is water damaged and does not work properly. You also do not want to try to charge it any further. What you want to do is to clean it properly. Disassemble your phone using these guides. Once it is disassembled, you do need to clean it properly. You will need high grade isopropyl alcohol and a soft brush. Use this guide to see how to clean it. Even so it was written for an apple iPhone3G all the points are still pertinent to your phone. Do not forget to remove the EMI shields for proper cleaning. While you are cleaning it, check for any broken, missing or burned looking components. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. If you do not want to do it, sell it on ebay or other places as a water damaged phone. Do not expect to make lots of money with that sale since it is a damaged older model. Hope this helps, good luck.
Punteggio 2
3 Commenti:
Question? Would a place be able to fix this for me? And the cost? And how much should I ask for it on eBay? I don’t think I can do that repair myself. You are very talented.
da
It's an expensive fix as it's quite time consuming to take everything apart, clean it, fix it, reassemble and so on.. I wouldn't suggest such a repair for a water damaged 5s.
da
@meghan009 not sure where you are located etc. since that will play a role with the price. It will most likely cost you more than you will get in return for the phone. Check some places online that offer water damage repair or if you are in Canada contact @refectio since he specializes in this repair.
da
Aggiungi la tua risposta
meghan balmer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 41
Tutti i Tempi: 3,024
