Salta al contenuto principale
Standard and high definition handheld video cameras by Sony.
sony handycam TRV608 code 31:22 Film does not roll
Everything else works okay electrical. But the film will not roll to record. I have tried taking the battery out for 2 minutes shoving it back in. Hitting the reset button nothing helps. Smacking it a few times does not help. some say there is a black roller in there. There is not on this model to fiddle with. Got any solvent ideas?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Paul Gibson, looks like a slap on the back is your resolution :-) anyhow read the forum on here and see if that helps you out. http://www.pechorin.com/m/2004/10/23/Err...
then there is a little bit more of a technical error resolution on camerahacker.com and here are the images that you need to check out on your cam and see if it looks like something that might be wrong with your cam. Hope this will help you out.
Here is the good news. I just found the SERVICE MANUAL for your camera and have it for you to share on my file server. You will have to download all 3 parts. This should help you fix your camera.
Part 1
Part 2
Part 3
Punteggio 2
1 Commento:
+ nice research
da
tHAT PART IS SO DAINTY i WOUNDER IF IT IS MISSING. bUT IS WHAT i THINK IS THAT THE MOTOR IS SHOT BECAUSE IT DOES NOT SEEM TO TURN
Punteggio 0
1 Commento:
YOu do have access to the field manual, take it apart and check it out. It tells you what to look for as well as the witirng and traceson the board to make it easier to troubleshoot. I am certain you will get there :)
da
Aggiungi la tua risposta
Paul Gibson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,808
