Salta al contenuto principale
Questa fotocamera fa parte della serie HX di Sony. La riparazione di questo dispositivo è simile a quella delle altre fotocamere della serie HX e richiede cacciaviti e strumenti di apertura.
How to change the battery broken door
How to change my broken battery door on my Sony Cyber-shot DSC-HX400?
Rgds
M. Picard
Update (11/25/2017)
Immagine
Here is the good way to remove it but I don't know how to remove the grip handle.
Questa è una buona domanda?
Punteggio 1
1 Commento
No I dont. Can you help me?!
da
Aggiungi un commento
5 Risposte
Soluzione prescelta
I received the battery cover today and replace the door part easily.
Immagine
Punteggio 1
Risposta più utile
This picture taken from one of the repair guides seems to indicate that if you take the back off you can probably slide out the hinge pin. But note carefully how the spring is located so that it operates correctly after reassembly. (This guides are marked "Difficult", but really aren't.)
Immagine
Punteggio 1
2 Commenti:
Hello Thanks for your answer but the hinge pin must be removed from the other side, under the grip handle. Do you know how to remove the grip handle?
da
da
The battery door is in 2 parts, the hinge part and the door itself, get a flat blade and gently prise the door part from the hinge section it will slide off easy and then just click in your new part, easy peasy.
Garry
Punteggio 1
You can do it even easier! The hinge part has a little rectangle hole at the end of the hinge part! Put your nail underneath and you flip the door part easily from it!
Punteggio 1
1 Commento:
there's 2 holes see can you send pictures of the hole that you're talking about?
da
I've made a little hole just in front oh the pin in the grip hand. I pushed the pin. I removed the broken door and I did the reverse to put the new one. I plugged the hole with rubson. Around 15 mn to do that.
Punteggio 0
Aggiungi la tua risposta
Andreï Picardowski sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 4
Ultimi 7 giorni: 13
Ultimi 30 giorni: 58
Tutti i Tempi: 2,752
