Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
How to put a screw hole back after long screw damage
Hello,
I have a question about the long screw damage. I have recently taken apart an iPhone 6 plus which had no backlight and I took the bottom right screw hole off. I then removed the layer and I have given up on the repair because I have a buyer that wants to buy the phone. How can I put the screw hole back in its place when there is no solder that I can attach it to?
I am grateful for all answers, thanks
Questa è una buona domanda?
Punteggio 0
1 Commento
i would leave it off the board and usually cover it with solder mask
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
You can solder it back on. Just place it and sit your soldering iron on top of the socket, it will heat enough to solder itself back on.
Punteggio 1
2 Commenti:
Yes but there isn't anything to solder it too and surely the screw hole will short every trace that touches it to ground?
da
Oh yeah if you got rid off the ring then don’t put it back on!
da
Aggiungi la tua risposta
Tom sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 6
Tutti i Tempi: 106
