Salta al contenuto principale
Lanciato il 24 ottobre 2011 / processori quad-core Intel Core i7 da 2,2, 2,4 o 2,5 GHz
405 Domande Visualizza tutte
Missing capacitor on Logic Board
Hi,
My macbook had the GPU issue so i decided to use the oven method to fix it. To my suprise, i booted my macbook and no more graphic issues. My new issue is that the HDD is not being detected anymore. So i checked on the logic board and i saw the connector being loose because of the oven method. So i decided not to put it in the oven anymore but use a heatgun. So when i used the heatgun to put it back on, i accidentally hit some capacitors next to the connector and lost them.
Would anyone know what the capacitors model are? Thanks!
Questa è una buona domanda?
Punteggio 0
1 Commento
Thanks for the info and details. Would you know where i can purchase these? Unfortunately i am unable to find them online.
Cheers!
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@sch3ck this is not diagnose your logicboard since you've already done that. This is only to identify to missing components
Reference designator C4501 is a 0.1UF 10V 20% capacitor in a 402 package
Reference designator R4531 is a 4.7Ohm 1/16W 5% resistor in a 402 package
Reference designator C4531 is a 0.001UF 50V 10% capacitor in a 402 package.
Punteggio 2
Aggiungi la tua risposta
Reiner Scheck sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 126
