Salta al contenuto principale
La versione con solo il Wi-Fi dell' Apple iPad Air, numero modello A1474. Disponibile nei colori grigio siderale e argento, ha un processore A7 custom ed è disponibile con memoria da 16, 32, 64 o 128 GB.
299 Domande Visualizza tutte
Replacement iPad Air screen spazzing
I’ve had my screen replaced 3 times not by Apple but due to the screen unsticking which I later found out that company bent my frame, It’s now started to spas out by itself so I can’t touch it or type anything. Does anyone know a fix before I buy a new iPad? Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Ghost touch on Airs and Minis is due to the company not insulating the edges of the digitiser, so it shorts against the frame and causes touch to work by itself or cut out.
See this answer for details Digitizer activating itself after digitiser replacement
Punteggio 3
Take it to a more reputable repair place. Ghost touching on a screen is common with cheap screens. If you use a high quality screen, and high quality adhesive (along with good repair and frame cleaning practices), you will get a screen that doesn't lift and works like it should.
Punteggio 1
1 Commento:
The only problem is a it’s more expensive to replace than my iPad is actually worth, is there a cheap solution?
da
Aggiungi la tua risposta
wlmsslsmskal sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 284
