Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
Faild to setup touch ID
When I update my phone to IOS 11 the touch ID always show me ‘unable to complete touch ID setup
-I’ve delet all setting
-return to ios 10
-i’ve not open or fix any thing in the device
New one)
Still not working
Questa è una buona domanda?
Punteggio 0
2 Commenti
which version of 11 IOS is your phone ?
da
The last one they update it yestarday ios 11.1.1
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Sometimes I've seen touch ID restarting to work after 3/4 hard resets performed. I ignore the reason behind such behaviour but by experience I'd try that too before surrender.
Punteggio 1
3 Commenti:
How can I do it
Is it press home B and power B ?
da
Power button+home button pressed together until it reboots. When you see the apple logo release and let boot normally.
da
I’ve try it 3 times , still not working also it’s gutting more hot
da
Risposta Più Utile
If you are sure nobody has opened the phone and performed unauthorized repairs, only Apple can fix this.
Punteggio 1
3 Commenti:
It's not suppurt by apple any more. Because it's old.
da
Yes it is supported, you just need to pay for it.
da
Ammm ok i will check up thanks
da
Aggiungi la tua risposta
Kadhem AlShaks sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 6,440
