Salta al contenuto principale
The Samsung Galaxy J1, released January 2015, model number SM-J100VPP/SM-J100H.
107 Domande Visualizza tutte
How can I access my phone Data when my screen is broken?
I broke my screen and I can't even respond to a call therefore .my phone can't even work by touching. I had installed some ADB to debug the phone hence it only works as media PTP but when I try to access by USB. I see no document whatsoever.
Questa è una buona domanda?
Punteggio 0
1 Commento
is your phone locked? if yes, can you unlock it?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Unfortunately you will need the display to respond to touch.
If you use smart switch to help extract the data from it, or plugging the unit to a computer, will required permission to enter the unit. On that note, if you want the data in the phone repair the screen.
Punteggio 1
Aggiungi la tua risposta
dallal bouguenina sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 116
