Screw inside the phone
Anyone has any idea what size screw goes into here?
(Photo will be added in a min)
Questa è una buona domanda?
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
The screw you are mentioning goes to the taptic engine (Vibrate function). There are 2 of them and one is there already. Remove the other and try to match it up to one you already have in your set. This screw is not critical to the operation and would not hurt to find one that just fits good.
Commenti:
Was scared incase putting any similar ones on would cause damage so that's good to hear, thank you!
da Sarah
The screws that have to be exact are the ones that hold the shield on to the LCD flex cables. Having the wrong screw can cause "Long screw damage) to the Logic Board since the logic board is under those screws. The Taptic enging screws down to the housing of the phone :)
Good luck! :)
da Michael
It’s a tiny one that you can buy on eBay .
If you have any questions or concerns please comment below. Thank you
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 61
