Why did the speedometer gauge stop working?
I replaced speed sensors and instrument cluster but gauge on speedometer doesn't move neither does the numbers on odometer.
Questa è una buona domanda?
It is possible the electrical wire connecting the two is broken or grounding. You can use a multimeter to find out if there is a break in the wire.
Check for an open in the wire harness to the speed sensor form the PCM.
At the PCM connector C2 (middle one) Terminal 25 Dark Blue/Black and Terminal 28 Light Green/Black.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 319
