Salta al contenuto principale
Processore dual core Intel i7 da 2,2 GHz (Turbo Boost fino a 3,1 GHz) o quad core Intel Core i7 da 2,5 GHz (Turbo Boost fino a 3,7 GHz) con 6 MB di cache L3 condivisa.
467 Domande Visualizza tutte
Changed screen and now have only white screen when turn on computer
I changed the display screen with new one, turned on and get a white screen? checked all connections, even plugged in broken screen and it still lit up on part of glass not cracked. any ideas?
Questa è una buona domanda?
Punteggio 1
2 Commenti
What happened with the previous screen to need a replacement ?
da
Daughter dropped off desk and cracked the screen, ultimately had to send to Apple and was fixed
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
The original screen had a small crack after falling off a desk and the bottom half of the screen was not working. Ordered a replacement screen and the replacement screen was faulty.
Punteggio 0
Risposta Più Utile
surely this is a software problem. Try starting up from an external USB device with a known good system on it. If it boots, run Disk Utilities from the external drive and see if that will do the trick.
Punteggio 2
Maybe you have not connected all the wires. If it is not of this then you will need programming pairing which only Apple does, and because you replaced the screen yourself they may not do it because it is Apple .
Punteggio -1
2 Commenti:
Never heard of that before. There is no programming a screen.
da
I like to see some validation of this programming pairing. Could you give us a link?
da
Aggiungi la tua risposta
herrky sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 201
