Why is dirt escaping from my vacuum?
The dirt is spilling out of my vacuum and will not suck in more dirt.
Questa è una buona domanda?
Dirt may be escaping from your vacuum due to one or two things:
1. The filter on the inside of the dirt trap bag may be loose or unlocked. This may cause dirt and dust to flow freely and escape through either the detachable portion of your vacuum or the end by the head and brush roll.
2. Your handheld portion which holds the filter may be loose or detached at a certain point. Re-check to make sure that it is secure and fastened.
Hope this helps.
Ben
Ok, how do I fix this problem ?
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 144
