Salta al contenuto principale
Guide e informazioni sulla riparazione per la quarta generazione della BMW Serie 7 / piattaforme E65, E66, E67 ed E68.
Engines Stalls when going over 50 miles
i am having problem when the car is lean downward engine stalling or going over 50 mile. i have changed all the coils and plugs what else i should i do. the car engine code still shows miss fire cylinder 5 7 and 8
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
You may want to check the pressure on the fuel rail. You should also check the wire harness for the coil packs on the cylinders that are missing . Pay particular attention to the ground wire for the rail . with a hot engine carefully inspect the wires to the coil packs and to the injectors feel for mushy wires that blister up when the engine is hot. Hope this helps
Punteggio 2
Aggiungi la tua risposta
Jesse singh sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 15
Tutti i Tempi: 496
