Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modelli 1660, 1774 e A1785. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
1364 Domande Visualizza tutte
iPhone 7 plus Camera not working after screen replacement
Hi,
I've just replaced screen iPhone 7 plus for a customer, after that she checked and both front and back camera are not working(I don't know if she broke before or I did it). I have tried to reseat front camera but no help. I replaced aftermaket front camera and it won't work too(I heard aftermarket camera won't work on ios 11???). I haven't tried original camera yet. PLease let me know what happen?
Thank you very much!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hello,
I would recommend an original camera as they tend to always work. You can find these on eBay and ifixit but if you are searching on eBay put in a genuine Apple iPhone 7 plus camera. The best ones that I use are used but high-quality new parts are available on ifixit. Here is the link: iPhone 7 Plus Dual Rear Camera
iPhone 7 Plus Front Camera and Sensor Cable
If an original part doesn't work then this may be a motherboard problem. Also, have a look at the connectors and the connections you are making to the board=. Sometimes they can be a bit off and make a problem. Hope that helped
Immagine iPhone 7 Plus Front Camera and Sensor Cable
Prodotto
$29.99
Immagine iPhone 7 Plus Dual Rear Camera
Prodotto
$99.99
Punteggio 1
try disconnecting the front camera and powering the phone on, if back camera works then its your front flex or connection
Punteggio 0
Aggiungi la tua risposta
kardon3000kardon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,325
