Salta al contenuto principale
OnePlus' second entry into the Android phone market, the OnePlus 2, was released on August 11th 2015.
Glass removal and substitution
Hi everybody, My screen glass is damaged and I'd like to substitute it with a new one that i found for a very low Price. Can I remove only it for example heating the glass? Everything is working fine so i'd prefer to not disassemble the entre Phone
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The disassembly isn't simply heating the glass.
Then you have to spend hours trying to remove the existing glue.
Then you have to purchase loca glue and a UV light.
The amount of extra work and equipment you need to purchase will not be worth it.
Punteggio 1
2 Commenti:
What does he need to do to fix it?
da
The whole assembly is around $23USD
https://www.ebay.com/itm/LCD-Display-Tou...
and a roll of adhesive is $3
https://www.ebay.com/itm/3M-3mm-LCD-Scre...
da
Aggiungi la tua risposta
Alessandro Balduzzi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 65
