Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
Low volume through earpiece
Hi everyone. It seems like when taking a phone call or listening to voicemail, the volume is very low. I thought it was the ear receiver so I replaced it, only to have the same results.
Thanks for any help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Could be dirt, or misalignment of the rubber thingy gasket (or whatever it is called. Try opening up again, and scratching on the metal part, and see if you can see through to the other side.
Have seen in rare cases that it is actually the front camera flex, that needs replacement also, but try cleaning and aligning first
Good luck!
Punteggio 1
1 Commento:
I will give it a try. Thanks for the advice.
da
Aggiungi la tua risposta
Scott sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 282
