Un discendente dello smartphone LG V10, simile all'LG G5, rilasciato il 29 settembre 2016. L'LG V20 si distingue per i numeri modello F800, H910, H918, H990 DS Dual, H990N Dual, H990 T, LS 997, US 996 e VS995. È disponibile con finitura titanio, rosa o argento con 32 o 64 GB di memoria interna.
Most often the lens itself is not broken, but just the glass that covers the lenses.
At first I thought that was my problem and had the lens replaced.
Then it happened again!
(I was using a case that was hard to remove and pressing against the glass covering the lens to pry off the cases - bad idea.)
If that is your problem problem there are separate lens glass replacement kits available for much less money and they are much easier to install!
This is the $10.95 kit that I got from Amazon and used to fix it:
Unifix Rear Back Camera Lens Repair Cover Glass Replacement For LG V20 F800L H910 H915 H990 LS997 US996 VS995 + Tool Kit (Dark Grey) Unifix
Sold by: Unifix Direct
Came with full clear instructions and info on how to find a YouTube tutorial video.
da Floridian
