Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
Replaced CPU with i7 - now 1 LED blinking
Hi,
Model: iMac "Core i5" 2.7 27-Inch (Mid-2011)
I replaced the i5 CPU with an i7 2600. But on boot I got a blinking single LED on LED1. Reading up that normally means insufficient power.
The main fan would spin cycle up and down.
I put the i5 back in and it boots fine.
Things I'm not sure about:
  • I'm assuming the CPU is good, but can't be 100% sure
  • I didn't put the RAM back in when I tested the i7, but normally you'd get a long tone.
Anything else I can try?
I'll have another go when I've got more time and double check I've seated all the cable correctly etc...
Big shame if it doesn't work - I was looking forward to the upgrade :-(
Thanks!
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi i have the same problem with a1419 late 2013 led # 1 blinking, so i bought i new power supply. Installed and i get the same blinking Led #1 so sad.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Ok - so I pulled it all apart and put the i7 back in.
Check all the cables, powered on and 3 green LEDS!
So all good. I put the screen back on and it's now all running just fine.
Side note: Awesome setup - picked up a really cheap 2011 iMac 27" i5 model on eBay with a damage case. Picked up this used i7 CPU on eBay as well. Installed 32GB RAM and 3x SSDs insides.
This thing flies! Totally awesome iMac for well under a thousand dollars. Same spec on a new one was AU$5.5k.
Punteggio 1
What MacOS are you running?
I would think you have a bad chip here or you put it into the socket incorrectly.
Punteggio 0
1 Commento:
I don't think with these ZIF CPUs you can put them in incorrectly can you?
OS is High Sierra - but it doesn't even complete POST, so it's not booting the OS yet.
But yes, a bad CPU is a possibility :-(
da
Aggiungi la tua risposta
Greyson Blaise sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 100
