Sim Card in slot without tray.
the sim card was put in the slot without the tray insert. How do I get the sim card out?
Questa è una buona domanda?
This video explains how to remove it.
It is likely you will need to disassemble the phone.
You can cut a credit card you don’t need in the width of the sim card slot, apply on one end of it super glue. Here you need to insert the sticky part in the sim slot, make sure it touches the sim, wait a minute or two for the glue to dry after which you pull the credit card together with the sim. It worked for me.
Let the gravity work shake it back and forth (fast movement) while keeping the sim port down.
The sim card is too far in the slot. Shaking the phone doesn't do anything.
I simply took a safety pin and bent the tip @1/16” to a 90° angle and used it as a hook tool. Easy peasy and it'll take longer to locate a safety pin and pliers than to get the card out.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 24
Tutti i Tempi: 5,238
