Salta al contenuto principale
Model A1213 / 8, 16, or 32 GB capacity
216 Domande Visualizza tutte
Earbuds only come thru in one speaker.
If I push the earbud jack in all the way I only gett sound in the left side. But, if I pull it out just a little bit I get both speakers working. The problem with that is, the jack won't stay in that position.
Do I need special earbuds for an Ipod Touch or do I need to replace the audio jack?
Questa è una buona domanda?
Punteggio -1
1 Commento
Try it with another set of earphones first.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
it sounds like a faulty headphone jack to me, especially since you get both channels if you pull the plug out slightly - I've seen this exact symptom on various old audio gear before if one of the contacts in the jack doesn't make a solid connection with the plug.
do confirm your earphones are good on another known good audio source, but if they are your headphone jack is the problem.
Punteggio 1
Can your order a headphone jack cause this is the same problem with me
Punteggio 0
Hi guys,
Because the headphone jack is attached to the logic board (soldered on the logic board), replacing the headphone jack might require special tools and extreme care. It might not be a good idea to do that unless you have all the necessary tools and are willing to take the risk.
check this link on Step 10: iPod Touch 1st Generation Logic Board Replacement
Dave, I agree with Bac that it sounds as if few connectors inside the headphone jack got loose or bent. You can check inside the headphone jack using a small keychain flashlight to see if it's true. You might find something tiny but strong enough to bend the connector back to its normal condition if the connector's bent. I know it's not that easy to do, but that's all I know.
Hope you can get it back to work normally.
Regards,
CHB
Punteggio 0
Aggiungi la tua risposta
Dave sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,710
