Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
Touch ID not working after replacing home button cable
Hi, I recently replaced my home button cable after accidentally ripping the home button cable while replacing my phone's screen, I bought this part https://www.amazon.com/dp/B00XNA80Z6?ref... After successfully installing it, I found the the home button works too go home and things like that. However the touch ID does not work. Any suggestions?
Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Unfortunately, only the original home button will work for TouchID. The home button and logic board are paired, so you'd have to replace both if you want TouchID functionality. Here's another discussion about it in case you're curious: Any possibility to replace Homebutton AND have Touch ID still working?.
Punteggio 2
2 Commenti:
UPDATE: I just found this article that shows a glimpse of hope on the horizon (pun intended): https://ios.gadgethacks.com/news/after-e...
da
Oh I had thought since it was just the cable or would be fine
da
Aggiungi la tua risposta
Monica Alexander sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 5,976
