Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Screen replacement - black screen
I smashed my phone and it wouldn’t respond to HDMI output, let me sync with my laptop or make any sort of noise. I bought a £20 replacement screen off eBay and fit the new screen myself. However, the screen wouldn’t display anything but black. The phone would light up and black screen and allowed me to get on it to recover photos - it worked with HDMI, keyboard and made noises etc. I kept trying to get it to display something by removing and reinstalling the new screen...nothing. Then while the screen wasn’t attached to the housing properly it lit up and displayed correctly...until I lifted the screen slightly and GONE. It has done this very intermittently, having displayed the screen for a few seconds every few days. What could be the issue here? Is it the screen or the phone? Do I need to get a better screen or clean the housing? It can’t be the logic board cause it still works, it can’t be the screws because they were put in correctly. The strange thing is that it has displayed a set of blue lines at times. I want to know whether it’s more cost effective to bend the case back and fit the screen or claim on insurance? Thanks a lot
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Cainthat from what I am reading it can be one of two things.
1. It's mostly likely a faulty screen that you purchase. The only way to see if the screen is the issue is to try another working screen. If that doesn't solve your problem then its probably issue number two.
2. Backlight chip could be damaged. This is very common on older devices like the iPhone 6 . This repair would involve soldering and can be expensive. If you have this problem I suggest just using the insurance or get a quote from a local repair shop.
Hope this helps
Punteggio 1
99% sure it's the screen if lifting it up made it work. Where the ribbon is fused to the LCD will have come unbonded.
Punteggio 0
Aggiungi la tua risposta
Catinhat sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 6
Tutti i Tempi: 98
