Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
Will I get error 53 if I upgrade from iOS 11.03 to iOS 11.1?
I had read about error 53 where issues with the touch ID would cause the iPhone to show error 53. I have read that this error was removed last year.
I was repairing my iPhone 6 Plus shattered phone last week and accidently broke the Touch ID cable and have been using the assistive touch ever since. I would like to upgrade from 11.0.3 to 11.1 when it comes out and would like to know if it is safe to do so over the air (without using itunes) and not get any iPhone bricking error. Thanks
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hasan Ahmad you should check with @refectio on this. He has a great write up on the iOS on here https://www.refectio.ca/blog/ios11-touch...
Personally I believe that you will be okay and you will not get an error 53 or similar.
da
I agree, I have no direct experience yet with iOS11.1 but Error 53 was settled a while ago.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Punteggio 2
Do not upgrade your phone will be bricked on recovery mode so keep up with the same version even I have a iPhone not working for the same reason
Punteggio 0
Aggiungi la tua risposta
Hasan Ahmad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 234
