Salta al contenuto principale
Lanciato nel giugno 2009 / processore Core 2 Duo da 2,66, 2,8 o 3,06 GHz
300 Domande Visualizza tutte
Display flickering in pink/red?
So the display on my Macbook started to flicker in pink/reddish every now and then. I hooked up a second display and everything is fine there, even when it's flickering on the Macbook screen.
From my research I guess this could be either the display cable or the inverter board?
Or could it also be the logic board?
Should I replace the cable first and then move on to the inverter board?`
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Your display has reached just about its end of life. Time to replace it.
Here's a new one, used ones can be had for less:
https://www.ebay.com/itm/mid-2009-15-Mac...
Here's how to get it off.
MacBook Pro 15" Unibody Mid 2009 Display Replacement
Here's how to replace the guts: https://www.youtube.com/watch?v=_k6vJUnG...
Punteggio 2
4 Commenti:
So you mean I have to replace the whole LCD display unit?
da
No just the guts.
da
Ok, before I order any spare parts I just want to make sure that the display is the actual problem.
How do you exclude the other parts like the inverter?
da
Then Google Pink monitor,
da
Aggiungi la tua risposta
Oliver Hirsch sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,737
