Salta al contenuto principale
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
How much is it to fixed my screen
My screen is shattered how much would it cost to get it fixed
Questa è una buona domanda?
Punteggio 16
14 Commenti
How much is it to get my screen fixed on my zte max pro
da
My phone screen the glass part is shattered from the top left corner. How much would it cost to fix the screen?
da
How much is it to fix my screen zte max pro
da
how must do it cast to get my phone screen fix
da
How my will my zte phonecist to fix the screen
da
Mostra altri 9 commenti
Aggiungi un commento
3 Risposte
Soluzione Prescelta
If you wanted to repair the phone your self, the display assembly is around $30-35 USD.
It would likely be $20-$40 labor for a shop to do it.
https://www.ebay.com/sch/i.html?_from=R4...
Punteggio 9
4 Commenti:
My phone cracked up
da
It's easy to change the screen. Buy the screen and I'll change the screen for u for free.
da
Can you walk someone thru the repair via webchat?
da
How much is zte phone screen model Z982
da
Buy oem screen on eBay 28 bux, prolly 20 labor from "pro..." Or YouTube that ish yourself.
Punteggio 3
1 Commento:
My phone drop in to water and the screen blank out
da
They are many places where you can get a display dependent on your location. See the guide below.
ZTE ZMax Pro Display Assembly Replacement
Punteggio 3
Aggiungi la tua risposta
Azea Brown sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 15,434
