Salta al contenuto principale
Annunciato il 16 ottobre 2014, identificabile dal numero di modello A1347 e EMC 2840.
RAM beep codes on 2014 Mac Mini
I have a late 2014 mac mini that is giving me 3 beeps on start up. Traditionally this a ram issue, is there anyway to save this computer, as the RAM for this machine is soldered to the board?
Thanks in advance.
Questa è una buona domanda?
Punteggio 1
2 Commenti
In a desperate attempt to salvage this thing I figured I might as well try to hit the solder connections with some rubbing alcohol and it worked?! YAY!
da
Congrats! Hopefully that fixed whatever issue the RAM was having!
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
If the RAM has failed there is nothing you can do as Apple Soldered the RAM in ;-{ Sorry.
Here's the beep codes to be doubly sure: About Mac startup tones.
Punteggio 1
Hi Taylor,
Sorry to hear that you're having RAM issues, @danj's post regarding beep codes most likely proves there is an issue with the RAM. However, we do sell replacement logic boards for that model of computer if you're interested. Currently, they're out of stock, but I know we have one arriving early next week.
- Jasen
Immagine Replace a logic board (motherboard) compatible with the Mac mini (A1347, model MGEM2LL/A) small desktop computer. Fix processing issues like unexpected shutdowns, reboots or water damage.
Prodotto
Mac mini A1347 (Late 2014) Core i5 1.4 GHz Logic Board
$174.99
Punteggio 1
Aggiungi la tua risposta
Taylor Struna sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,657
