Salta al contenuto principale
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Domande Visualizza tutte
Audio out dead (low volume + static) after battery replacement
Hello !
I tried to replace the battery of my iPod classic (160gb, thin). I broke the cable of the hold button, but everything else seems to be alright. When I listen to musics, the volume is very low and there's a lot of static, which makes the iPod impossible to use.
Do you think replacing the hold button (and the audio jack at the same time) would fix the problem, or I definitely broke the iPod ?
Thanks for your help !
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@perdouille replace the cable. This sounds like you are shortening the audio IC. Your headphone jack and hold button share the cable. Here is the guide for it iPod Classic Headphone Jack & Hold Switch Replacement and the part is available right here iPod Classic (Thick) Headphone Jack & Hold Switch
Immagine iPod Classic (Thick) Headphone Jack & Hold Switch
Prodotto
$29.99
Punteggio 1
2 Commenti:
I bought a replacement, let's see if it works ! Thanks for your help !
da
It looks like it's working ! Thanks a lot !
da
Aggiungi la tua risposta
Lou sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 119
