Salta al contenuto principale
La famiglia MacBook è stata introdotta nel maggio 2006, sostituendo l'iBook nel ruolo del laptop Apple indirizzato al mercato consumer.
3787 Domande Visualizza tutte
Domanda Chiusa
Why is there no sound from my internal speakers?
There is no sound from the internal speakers, but everything is fine with headphones plugged in. There is a red light coming from the headphone jack.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The red light means your digital audio out has switched on. You can insert a plastic toothpick in the hole and try and switch it off. The switch should be at the 3 o'clock position and go towards the 6 o'clock position. Some people also have had luck inserting their headphone jack and pulling out a few times. Another recent report was that inserting the headphone jack and turning it in the hole helped.
Punteggio 4
Thank you, mayer. That was a quick fix.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,386
