The backlight is not working.
My phone just turned off and then when I turned it on it doesn't lit anymore
Questa è una buona domanda?
@ameliadepp could be the backlight in your display or the backlight driver as well. I would start with a new display assembly. Use this guide Samsung Galaxy J1 / J100 Touch Screen & LCD Replacement for that, If nothing else it will be your known-good point for further troubleshooting. Use these as your guide for further troubleshooting if it should be necessary
Vertical irradiation the screen with a strong light, if you can see the pictrue, the back light is bad and you need to repalce a new LCD screen. If you cann't anything, the display may broken.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 2,984
